Best Multitools for Tactical Purposes: FAQ & Best Product Reviews
- Posted by MikeKnopfler (1) Offline
For those in the line of fire such as law enforcement officers, firefighters, EMT specialists, and military personnel, a good multi tool is an absolute must-have in the gear list. One that’s well-designed and well-manufactured is going to get you out of many different tough situations. And since they’re partially designed to help in life-or-death scenarios, it might even save your life.
In this article, we’ll be answering all of the frequently asked questions about best rated tactical multi tools. At the later half of the article, we’ll also be introducing some notable top rated multi tools for your consideration.
➤➤➤ See This Page: thekinglive.com/best-multi-tool.html
Frequently Asked Questions About Tactical Multi Tools
What Makes Tactical Multi Tools Special?
Tactical multi tools can be differentiated from EDC or electrician multi tools by their special selection of tools. Other than the popular tools such as pliers, wire cutters, scissors, and knife blades, you’ll also find within tactical multi tools things like seat belt cutter, carbide glass breakers, and firearm maintenance tools. They aren’t commonly found on your average, civilian-grade multi tools.
Tactical multi tools also tend to have more robust construction. Because they’re expected to be used inside of hostile, extreme environments such as the battlefield, they wouldn’t be able to do their job without being tough. The majority of good tactical multi tools are made from high-quality stainless steel. Some are even cast out of titanium.
What Are the Best Multi Tool Brands in the Tactical Segment?
There are many reputable names on the market that you can trust. Leatherman, Gerber, and Victorinox, for example. They make the best rated multi tools in-class and their portfolios are diverse with plenty of models for you to choose and at different price points.
You can’t go wrong buying from them (even if you have issues, their customer services are great.)
But out of the three names we listed, we recommend Gerber. That’s because the standard issue multi tool of the U.S. military is the Gerber Multi-Plier 600. If the U.S. military can find good use out of a Gerber’s product, you will most likely be satisfied with one in your gear kit, as well.
Can I Use a Tactical Multi Tool As a Civilian?
Certainly. There’s no law that prohibits you from owning a pair of tactical multi tools! As a matter of fact, they can work very well for survival purposes. Many most useful multi tools contain a seat belt cutter and window breaker, which would be life-saving in a car accident or rollover.
However, we still recommend you to look into more practical EDC multi tools, instead. Tactical multi tools are quite heavy and so can be very annoying to carry around. In addition, for the price that you paid, there would be several tools that you’re never going to use. Specifically, you will most likely never find yourself in a situation where you’d need to use specialized tools such as oxygen wrench or firearm disassembly punch if you’re an office worker or a student.
We have the best multitool reviews for EDC on our site, if you’re interested.
Best Tactical Multi Tools Reviews
1. Gerber Multi-Plier 600
Like previously mentioned, the Gerber Multi-Plier 600 is currently the standard issue multi-tool of the U.S. military. Although standard issue equipment tends to have mediocre quality (contrary to popular belief,) the Multi-Plier 600 scores very well among the consumers who have had the chance to use it.
The first thing that must be talked about is its special design. The Multi Plier 600 has a unique plier deployment, which makes it an extremely ergonomic pair of best rated multi tools to use. You’ll need some practice in order to fluently operate the sliding pliers, but once you do, you can deploy it one-handed easily.
The Multi-Plier 600 is quite heavy, weighing around 8 ounces (half a pound.) It’s quite large in size, too, so there’s no way you’re going to carry it around in your pocket. Instead, the multi tool comes with a sheath made from ballistic nylon that you can clip onto your belt.
Its heavy weight is because of the solid stainless steel construction. The locking mechanism for the tools are made from plastic, but the whole multi tool is durable enough that it shouldn’t be much of an issue. The plastic material seems to take impacts and shocks very well.
So, what does the Multi-Plier 600 come with?
Well, it has all of the basic tools that you’d expect from any good multi tool. It has a few knife blades, files, and drivers. You also have a can/bottle opener. There’s also a ruler etched right onto the handle of the multi tool, as well. The most unfortunate thing about this pair is that it doesn’t come with specialized tools like firearm disassembly punch.
2. Leatherman MUT
The Leatherman MUT is designed for military use from top to bottom. This is the best multi tool on the market to buy if you regularly have to handle firearms.
In terms of ergonomics, we haven’t found many reviews lambasting the MUT for not being comfortable or easy to use thus far. But the weight and the bulk of the MUT can be a turn-off for many people. At 11.2 ounces, there’s no denying that this is a very big multi tool. Despite the fact that it comes with a titanium belt clip, it’s going to be challenging for some people to carry around.
Leatherman MUT has a MOLLE-compatible sheath. If you have any MOLLE gear you can hook the MUT up to, it’s going to make the multi tool significantly easier to carry around.
The body is made from solid stainless steel. It can handle some rough-handling without giving you grief about it. A layer of black oxide also covers the bare metal frame of the multi tool to protect it against the weather and rust.
As for tools, you’ll have a variety of pliers, including needle-nose pliers. There are also wire cutters, electrical crimper, a few knife blades, bit drivers, a saw, a hammer, and bottle/can opener.
Then there are the specialized tools that are the true selling points of this model. You have a replaceable bronze carbon scraper to clean up your firearm. There’s a firearm disassembly punch for detail stripping and maintenance. Bolt override tool, No.8/32 cleaning rod and brush adapter, you name it, the Leatherman MUT has it. But the thing that caught our attention the most is the ⅜-inch wrench and front-sight adjustment tool. You can use it to calibrate the height of your rifle sight. It isn’t a tool that you see in every tactical multi tool.
Picked For You: Best Multitool: Top-Rated Multipurpose Tools for Every Task
Conclusion
These two are just a few prime examples for the best multi tools in the world in the tactical multi tool segment. If you’re interested in seeing more best multi tools options, our site has many other reviews for you to look through.
In the meantime, we hope that you’re satisfied with this article and have found your new multi tool in either of the products we suggested. You can check out the prices for them here through our site.
6 years 4 weeks ago - 2 years 2 months ago #1
by MikeKnopfler
2. Leatherman MUT
Conclusion
Last edit: 2 years 2 months ago by MikeKnopfler.
- Posted by TemplatePlazza (5433) Offline
HI, could you let me know the URL of your site so I can take a look?
6 years 4 weeks ago #2
