responsive banner and social stream conflicting
when i publish the responsive banner - social stream does not show properly - the 2 modules conflict with each other
13 years 9 months ago #1 by sanjiovani
Hello sanjiovani,
What about if you try to disable the jquery option in one of that module?
And let we see what happen
13 years 9 months ago #2 by ronysyz
I tried that and it is still not working - I invested into purchasing the modules - I would really appreciate fixing the conflict so I can use the module - it is delaying the launch of my site
13 years 9 months ago #3 by sanjiovani
Hello sanjiovani,
I can't see reposnive banner module published on your website so I decided to try it my self on my localhost.
And I found they are both working properly, so the problem maybe comes from your template or other extensions that you have installed. The key is, just make it sure that jquery is loaded only one time on your website.
I've recorded a video in here , please have a look :
d.pr/v/1Wal
13 years 9 months ago #4 by andy
