Minifrontpage pro - carousel failed to display slider & alignment is way out.
Hello Support :)
I just bought minifrontpage pro yesterday.
After installing the modules and display on my website, almost all the theme does not work as intended.
I have enable all settings and control buttons in the modules setting too.
I have input the modules at the bottom on the page section
Screen attached, please take a look. thank you so much
6 years 6 months ago #1 by cedric chan
The slider items is un-grouped too.
6 years 6 months ago #2 by cedric chan
Hi rvd119, I visited your website and looks like the module works properly.
https://www.dropbox.com/s%2Frjrjz7lz2kk0viv%2Frd57k.jpg?raw=1
https://www.dropbox.com/s%2F3bpqp254g6f2r1t%2Fd69y0.jpg?raw=1
Am I missing something?
6 years 6 months ago #3 by TemplatePlazza
Hi Admin,
Thank you for your prompt response.
you are right, its showing property on safari browser, and google chome
only in Mozilla firefox browser, shows the misalignment and no slider control. That is Strange.
6 years 6 months ago #4 by cedric chan
silly of me to not check on other browser. As I accustom to Firefox these years.
Any firefox settings should I change in order for the module to be display correct in forefox?
6 years 6 months ago #5 by cedric chan
I checked your website with firefox too and looks like it also works fine.
https://www.dropbox.com/s%2Fo4u5t9cj467o718%2F400y8.jpg?raw=1
Do you use the latest firefox version?
6 years 6 months ago #6 by TemplatePlazza
