Responsive Banner Nivo Bar
i noticed on your demo for Responsive Banner Nivo Bar, the animated navi bar is a dark color. i do not see any option in the parameters to change coloring. i get the animated navi bar, but it is transparent and the "prev and next" are white. how do i get the same effect you have in the demo.
your demo: demo.templateplazza.com/joomla/index.php...nner-slider-nivo-bar
13 years 9 months ago #1 by robert
Hi Stew,
There is a Theme option in the backend parameters. Have you tried it yet?
Please see attachment
13 years 9 months ago #2 by andy
i did try that. it shows the very hard to see transparent right and left arrows only, not the slide up animated navi bar
13 years 9 months ago #3 by robert
can you give a screenshot? Or can you enable it on your website so I can check it?
13 years 9 months ago #4 by andy
got it figured out. if i disable the "show navi" then it will show only the hard to see "prev" and "next". if i enable "show navi", then i does it just like the demo. thank you.
13 years 9 months ago #5 by robert
great. thanks for the confirmation :)
13 years 9 months ago #6 by andy
