Minifrontpage pro
- Posted by Alex (3) Offline
Hi there!
How can I translate the varius element ("reading more", "all" category, and so on) in minifrontpage site side?
Thank you in advance!
Alex
6 years 6 months ago #1
by Alex
Alex
Hi, You can translate the language file .../language/en-GB/en-GB.mod_minifrontpagepro.ini or you can also override the language from the backend. If you don't know how to override language you can follow this video youtube.com/watch?v=7beZ67_oQQs
6 years 6 months ago #2
Perfect!
How can I translate the "all" label in Ctagory line in portfolio layout? I'm not finding the specific file to translate.
6 years 5 months ago #3
by Alex
I'm sorry the 'all' label is still hardcoded. It will be fixed in the next update. In the meantime you can edit this file with your php editor : ../mod_minifrontpagepro/tmpl/portfolio.php search for 'all' word.
6 years 5 months ago #4
Fine! Found and modified. It's work even if it's hardcored.
Thank you!
6 years 5 months ago #5
by Alex
Thank you!
