Whatsapp dont work after update
- Posted by Soner (9) Offline
i use the Whatsapp Modul on this side: zahnarzt-al-dulaimi.de
after update dont work.
Howe can i fix this?
regards
6 years 2 months ago #1
by Soner
regards
- Posted by TemplatePlazza (5456) Offline
Hi, I visited your website and the module is working properly. Can you tell me the detail of the issue?
6 years 2 months ago #2
Hmm I found that the module doesn’t open the whatsapp module when send button is clicked. Please open the module backend and re-save the settings
6 years 2 months ago #3
Hi, does it work before? When you said 'after update', did you mean you update the wharsapp module or update your template or any other extension?
Because I found that all js are compiled into one js file and seems the whatsapp module's js call order is incorrect
6 years 2 months ago #5
Can you try to install extensions.joomla.org/extension/jquery-easy/ on your website? It looks like there's jquery ordering and multiple jquery call on your website.
6 years 2 months ago #6
