Minifrontpage problem to Skipped item
The module does not work if I want to start showing news for example with 130. I found this when I created 3 modules, in the first I had 70 news, in the second it was also 70 and 69 excluded, in the third module it was also 70 and 138 excluded, and the third the module does not work. Thus, I tried to conclude all the news from the site with pagination. Check out the elanschool.ru/lenta-novostej third button below.
6 years 5 months ago #1 by wladshein
Hi wladshein, Are you sure you have more than 138 articles in total?
I mean in the 3rd module, does it really have item to be displayed? What if you decrease the skipped item value, let say 30 items, does the 3rd module still doesn't work?
6 years 5 months ago #2 by TemplatePlazza
Hey. Yes, I have a lot of material on the site, about 1000. If I exclude 30 in the third module, then it works. You can view.
6 years 5 months ago #3 by wladshein
What if you exclude 130 in the first module. Does it work?
6 years 5 months ago #4 by TemplatePlazza
In the first module, I excluded 130 news items. The problem repeats, the module does not find it.
6 years 5 months ago #5 by wladshein
Try to find on what item number exactly the module starting to return an error. You can try with 129, 128, and so on.
When you already find it, let say 127, try to unpublish the 128th article, to see whether the issue comes from the article or indeed from the module itself.
6 years 5 months ago #6 by TemplatePlazza
