installation of WhatsApp Multi Agent
- Posted by Karin Hegmann (2) Offline
After installation of the module WhatsApp Multi Agent I see a blank white screen with the Button Text. Do you have an Instruction for the configuration of .htaccess and extentions like Admin Tools?
6 years 4 months ago #1
by Karin Hegmann
Strange ... have you added the agent feom the module backend? Can you share your website url so I can see it directly?
6 years 4 months ago #2
Thank you for your fast response.
That was strange, you are right. I added it from the backend and tested the compatibility with other modules.
Preparing a test installation for you I saw that we have an update for admin tools. After the update I started again and installed your module. It works
6 years 4 months ago #3
by Karin Hegmann
