Mini Frontpage same height
- Posted by Martin Kopp (7) Offline
Hello - is it possible to set a height for the Mini Frontpage Module so all the modules get the same height regardless of the content?
6 years 3 months ago #1
by Martin Kopp
Hi mako, can you tell me what minifrontpage theme do you use? Is it the default one?
6 years 3 months ago #2
I think so - i even don't know where to set a template... Thank you
6 years 3 months ago #3
by Martin Kopp
Sorry my question was not clear enough - the modules have the same height but if the title is only one line, the content starts not at the same position as a module where the title has more than one line. see wdm-zh.ch - if the title has 2 lines everything looks fine (below)
6 years 3 months ago #4
by Martin Kopp
Mini frontpage comes with some themes (layout) that you can choose from the module backendI think so - i even don't know where to set a template... Thank you
https://www.dropbox.com/s%2Fzbxnz0ph3pduuwo%2FMonosnap%25202020-07-16%252016-10-09.png?raw=1
Umm it looks like you are using the old version of mini frontpage. Can you tell me how did you get that? Please download the latest one at www.templateplazza.com/items/mini-frontpage-joomla-moduleSorry my question was not clear enough - the modules have the same height but if the title is only one line, the content starts not at the same position as a module where the title has more than one line. see wdm-zh.ch - if the title has 2 lines everything looks fine (below)
