Mini Frontpage Joomla 4
Tested Mini Frontpage with Joomla 4 and had some issues especially with the carousel layout. I was on Beta v2 and latest plugin update was for the Alpha.
I saw on Joomla portal that a new update for Beta was released. Where it can be downloaded? On the plugin page the downloadable zip file is the old one, from Feb.
Thank you. :)
6 years 3 months ago #1 by ckubs
Hi ckubs, can you tell me what the issues you found with joomla 4?
6 years 3 months ago #2 by TemplatePlazza
Strange... It works properly at my end. Can you tell me what minifrontpage theme you are using and what joomla template are using so I can try to replicate the issue.
The same issue I apparently had visiting on your demo page. Like there was no js loaded.
The demo site is using Joomla 3.x
6 years 3 months ago #3 by TemplatePlazza
