WhatsApp Documentation
- Posted by Coopera srls (14) Offline
Hi, where I can find WhatsApp extension documentation?
In particular, I have doubt on position (debug?).
If I setting only debug position it does not work, if I activate debug system (in global configuration) it's work, but I see debug log on-page.
Coopera
6 years 3 months ago #1
by Coopera srls
Coopera
Hi Coopera,
You can find the documentation.pdf file after you have extracted the package you have downloaded.
Basically you can publish the module in any position, it will work unless your template has any specific styles or javascipt rules.
Please try it, if it's still not working please let me know
6 years 3 months ago #2
Hi, we have some problem.
I tried module on the test site with YooTheme template but it's not worked fine.
I found that Jquery library isn't loaded. I loaded it and now it's work.
After, I tried module on the site in development, I set it in the same mode but I have an error that I don't understand (see image). The new site using another YooTheme template.
If I disable WhatsApp module the site is OK (without WhatsApp naturally).
Can you help me?
Coopera
6 years 3 months ago #3
by Coopera srls
Can you help me?
Coopera
I seemed to have connected it.
When I upload attach I see c:\fakepath\error.docx ??
And if I submit no attach is linked.
6 years 3 months ago #5
by Coopera srls
