Extra fields display in Minifrontpage pro
- Posted by Sissoko Cheick T (12) Offline
Hello, I'm using Minifrontpagepro for K2, when i turn on the display for extra fields, it displays on every place holder for exemple for the collage theme, it appears everywhere for all categories but extra field does not apply to all categories.
It is possible to publish the extra field only for the articles from the categories that have the extra fields assigned to them?
Thank you.
6 years 2 months ago #1
by Sissoko Cheick T
Thank you.
Hi Talla, I have updated the module with fix for K2 Extrafield. Please re-download the file and re-install to update
6 years 2 months ago #2
Because i've downloaded the module and re-installed it. the extra fields are still showing on all the articles.
6 years 2 months ago #3
by Sissoko Cheick T
Hmm strange. I'm unable to replicate your issue. It works properly on my local computer, the extrafields are showing only on items that have it on my local computer.
https://www.dropbox.com/s%2Fjzxce1z7q36uldl%2FHome%25202020-08-10%252007-38-27.png?raw=1
I'll make a more deep check on your website and let you know the result soon.
6 years 2 months ago #4
Hi Talla, I tried to access FTP but there's nothing in there. I can't see any files
6 years 2 months ago #5
Hi talla, I've been able to spot the issue and upload the update to your website. It should be working properly now. Please check
6 years 2 months ago #6
