Countdown not showing
- Posted by Moghees Siddique (4) Offline
I want to load the flip-clock but it's not showing. Needs to be centre top in the black bar. I've done a demo in the attached image.
6 years 2 weeks ago #1
by Moghees Siddique
Hi, what module position you have on the center top of the top black bar?
6 years 2 weeks ago #2
Not sure possibly top1 but i need it between the logo and the menu
6 years 2 weeks ago #3
by Moghees Siddique
Hi I've checked it, your template doesn't have a module position between the logo and menu, so you have to create yourself first. I'm not familiar with helix template but it looks like you can create one by using helix layout builder.
Additionally, it looks like the template has a jquery issue, you might want to fix it first before displaying the flip clock, because flip clock uses jquery
https://www.dropbox.com/s%2F174g61r8kkpfp1y%2FMonosnap%25202020-08-25%252008-02-02.png?raw=1
6 years 2 weeks ago #6
