Banner Carousel is forced 960px wide?
I have added the banner carousel extension to a website (clients.thedreamfoundry.net/mhb3/) and there is a problem with the width of the small side bar banners.
There is inline CSS being included to create a width of 960px for the containers of these banners. As a result they are breaking the layout and also making it so users cannot click on links adjacent to the banners.
Can you please help?
6 years 2 months ago #1 by JJ Spelman
try to add this css :
.carouselbanner {
  position:relative;
  z-index:0!important;
6 years 2 months ago #2 by TemplatePlazza
Thank you for your reply. But this doesn't really fix things.
if you look on this page: clients.thedreamfoundry.net/mhb3/index.php/government , the last banner at the bottom left, you can see the rotating banner slide across the entire width of the 960px.
Also if you look at the home page (clients.thedreamfoundry.net/mhb3/) the first banner next to the slide show is outside the page container. I want the modules centered, and because the carousel banner is set to 960px wide, the ad is centered outside the container of the page.
Why does the container have to be 960px when I specify 200px width for all of those modules??
6 years 2 months ago #3 by JJ Spelman
Umm this module uses old codebase and does not support responsive design yet. I'll have a look on the codebase and see if I can update it.
6 years 2 months ago #4 by TemplatePlazza
Hi jjspellman, we have updated carousel banner. Please re-download and re-install the extension
6 years 1 month ago #5 by TemplatePlazza
[SOLVED]
Thank you. This seems to have corrected the issue.
I also noticed that you allowed more options as far as ad transitions.
A great extension - thank you!!
6 years 1 month ago #6 by JJ Spelman
