WhatsApp Multi Agent not working
I installed the Module - it does looks fine, but it makes no response when i click on it.
I use the newest version on Joomla 3.9.21 with a yootheme pro template...
When i look at the console, it says jQuery not defined.
for any tipps i'm very thankful!
Maya
6 years 2 months ago #1 by byteKultur GmbH
Hi, Yootheme pro template doesn't load jQuery as default, you need to enable it from the template settings. https://www.dropbox.com/s%2F9h44kltpeuiu0ko%2FWebsite%2520Builder%2520-%2520Adriano%2520Ettlin%2520Consultign%25202020-09-02%252016-05-41.png?raw=1
I have enabled it please try again now.
6 years 2 months ago #2 by TemplatePlazza
thanks a lot!
I looked at the plugins to activate jquery and in your module - but I never got the idea of the template itself.
Shame on me!
thanks again!!
6 years 2 months ago #3 by byteKultur GmbH
No problem at all. Glad could help ;)
6 years 2 months ago #4 by TemplatePlazza
