Floating Buttons ACL
First of all I would like to thank you for the excellent work on the free plugin.
I would like to know if at any time it would be possible to add control of user groups to the buttons, it would be interesting to have this option.
Another improvement would be to be able to choose which side the button would appear on.
Thank you very much in advance.
6 years 1 month ago #1 by JACKSON MEIRA
Hi cropots,
Glad you like the module;)
You can do that by duplicating the module and set different access level for each user group.
We will add this function in the next update, in the meanwhile, you can add this code below to your css file, to move the buttons to the left side :
button.jfab_main_btn {
right:auto!important;
left:16px!important;
padding:0!important;}
.jfab_btns_wrapper {
left:0!important;
text-align:left!important;
.jfab_btns_wrapper button {
.sub_fab_btn {
    float:left!important;
    margin-left:20px!important;
.jfab_btns_wrapper > div {
    display:block;clear:both!important;
.jfab_btns_wrapper:first-child {
    margin-bottom:30px!important;
6 years 1 month ago #2 by TemplatePlazza
I tried this option to duplicate the module, but the buttons are overlapping and it doesn't have a very nice effect, unless I can control the position of each icon separately.
6 years 1 month ago #3 by JACKSON MEIRA
I have users with hybrid permissions, so even configuring a certain group in the module, it will end up loading 1 or more modules at a time. The ideal was to be able to control directly on each icon, which group could view.
Anyway thanks for the help.
6 years 1 month ago #4 by JACKSON MEIRA
I managed to get around the problem by changing the JS to create a class with the same name as the link in the main div of the button, I think it will work for now.
But think about this permission function by group, it would make the module more attractive than it already is.
6 years 1 month ago #5 by JACKSON MEIRA
Ok, I will update the module with access level for the menu items. Hopefully I can upload it today
6 years 1 month ago #6 by TemplatePlazza
