Minifrontpagepro for K2 (carousel)
Incompatible with IE 11
for example:https://www.configuration.cn
Normal display in Google browser
but on IE11 carousel disappear It turns into multiple single column and multi line images
How can I solve it
6 years 1 month ago #1 by hefeng
Hi hefeng,
This has been discussed few times on this forum and, and we decided to not support IE 11.
IE 11 is the old browser from Microsoft. Most developers suggest people to abandon IE11 because it has so many modern css support limitations and also latest javascript adoption support such as ES6.
Microsoft already dropped its support for IE 7 for windows 7 (but likely will continue to support it in Win 10) and encourage its users to use Edge browser. The global IE11 usage right now is 3% but it seems that the biggest contributor is the use of win7 in corporates (win7 itself already reached its end of life at Jan 2020).
6 years 1 month ago #2 by TemplatePlazza
In China, a considerable number of ERP and OA systems still use ie11, and many people are still using it. Can you help me? In the old version of ie11, the number of images becomes 1 in “carousel”, and in Google and edge, it becomes the set number
6 years 1 month ago #3 by hefeng
Ok, I'll try to find a solution and back to you soon.
6 years 1 month ago #4 by TemplatePlazza
Thank you very much for try to find this a solution,My email is This email address is being protected from spambots. You need JavaScript enabled to view it.
I am looking forward to receiving your letter. Finally, Thanks you once more to my help.
6 years 1 month ago #5 by hefeng
Hi Hefeng, We have uploaded the new version with carousel support for IE 11 please re-download then re-install the module
6 years 1 month ago #6 by TemplatePlazza
