Related Items Extended does not show images
187/5000
I installed the latest version of Related Items Extended but I am having problems loading the images it is grayed out.
I have checked the configuration and I see that everything is ok
What can be?
6 years 1 month ago #1 by Diego Palacios
Hi diegop,
Can you tell me how did you add the Intro Image on every articles? I found that every Intro Image on your articles return a full path instead of relative path.
For example, in article : Ozono troposférico y vegetación (xxx.xxx/administrator/index.php?option=c...e&layout=edit&id=867) you have this Intro Images :
xxx.xxx/images/publicaciones/ozono-tropo...ico-y-vegetacion.jpg
while if you use joomla intro images picker the path should be like this :
/images/publicaciones/ozono-troposferico-y-vegetacion.jpg
https://www.dropbox.com/s%2Fhgbc41uyn1gsjua%2FMonosnap%25202020-10-01%252005-44-30.png?raw=1
Please see this article to understand what I mean : Caminos divergentes con Jorge Cagigas
(xxx.xxx/administrator/index.php?option=c...e&layout=edit&id=844)
I use the Intro Image select button and re-select the Intro image then the path now is
images/publicaciones/caminos-divergentes-con-jorge-cagigas.jpg
https://www.dropbox.com/s%2F3opyfji2nmchs8y%2FMonosnap%25202020-10-01%252005-50-18.png?raw=1
and then the thumbnail is generated correctly :
https://www.dropbox.com/s%2F5ynn2hovqartg87%2FCmo%2520vender%2520en%2520modo%2520NETFLIX%2520-%2520HitLive%25202020-10-01%252005-53-12.png?raw=1
6 years 1 month ago #2 by TemplatePlazza
Ok, I already understood the point, but we have a problem about it and it is that all the images use the full path xxx.xxx/images/xxxxxxxxx/xxxxxxxxxxxxxx.jpg because we use a system that shares articles with other sites, so the image needs to have the full path, otherwise the images will not be seen in the other sites.
Ex: olewow.com/simplemente-wow/un-blog-wow
6 years 1 month ago #3 by Diego Palacios
I see. Anyway, how did you add the custom image path to the Intro Image?
6 years 1 month ago #4 by TemplatePlazza
1. The image is uploaded to the server with the Joomla system and then selected.
2- before inserting the initial path is added the hit.live/
6 years 1 month ago #5 by Diego Palacios
I see. It will need some code modifications to the php file ...
6 years 1 month ago #6 by TemplatePlazza
