mini k2 crashes page on module load.
- Posted by Siobhan Ramsey (5) Offline
I have installed mini K2 on my siite but it just crashes the page.
I have tiried turing jquery on or off in the settinggs and it makes no difference.
advice?
sandboxeducation.co.uk/index.php/services
13 years 7 months ago #1
by Siobhan Ramsey
advice?
no there is nothing else on the page. I made the pag with a featured joomla article i case that was the issue switched the menu to a k2 tiem and no luck. I turned jquery load on and off in the module option no luck.
I remade the module - no luck! I tried to add it to a accepted path with jquery easy in case that was an issue no luck.
So I am totally stuck.
there is a bug though becuase after I made the module and assigned it to a page it too over the menu and made that page the defualt menu hime page. I then had to go in and chnage this manualy by clicking the star back on the menu itme which is the home page,
I would really appreciare antyones help here!
I am running j 2.5 and the framework is JA T2
Thank you
13 years 7 months ago #3
by Siobhan Ramsey
Thank you
Really strange, can you switch the template to default Beez template for a moment to check whether the problem is persist or not?
13 years 7 months ago #4
I tired beez but did nto get a menu
so tried Gavipro tempalte and got this error
Fatal error: Class 'K2Model' not found in /var/www/vhosts/sandboxeducation.co.uk/httpdocs/modules/mod_minik2/helper.php on line 262
13 years 7 months ago #5
by Siobhan Ramsey
can you tell me what did you mean by
what minik2 and K2 version did you use?
13 years 7 months ago #6
does it working properly with beez or not?I tired beez but did nto get a menu
