background youtube not showing
  • Posted by valdenilson brito de araújo (15) Offline
Hi again admin, Im using 2 modules with minifrontpagepro in my main page.
1 - mansoryxt for news
2 - collage for youtube videos
The item 2 had a problem, its caused a blank page with this message in apache log:
Fatal error: Cannot redeclare class TmplPadraoGoverno01Helper in .../templates/padraogoverno01/helper.php on line 13
After change articles/category in the module, it worked, without blank page but the background youtube doesnt show.
Another quesiton, there is a way for change the thumbnail without clear files in "/images/thumbnails/mod_minifrontpagepro" when a image is replaced in the article??
Can you helpe me? Thanks!!
6 years 4 weeks ago #1 by valdenilson brito de araújo
Hi valdenilson,
Strange .. this error message seems coming from your template not from module. Can you tell me what article/category changes you have done to solve the problem?
Can you share the url to your website so I can try it?
Sorry, there is no such way at the moment. We can make the thumbnail is refreshed all the time but it will increase the server load
6 years 4 weeks ago #2 by TemplatePlazza
article ID 6576 - got blank page
the youtube background doesnt works.
acces's info in "site details".
Thanks!
6 years 4 weeks ago #3 by valdenilson brito de araújo
Hi valdenilson,
- Are you using seblod to add the article article ID 6576 ? Because when I try to add new article using standard joomla content using the same content as article ID 6576 have, it doesn't produce any error.
- Can you share temporary ftp access to your website so I can make some tests for the video not loaded issue?
- Anyway, I spot that you are still using PHP 5.5.9. Is there any reason you are not using php 7.x?
6 years 4 weeks ago #4 by TemplatePlazza
I don't use seblod in my articles, I always create standard article.
I have tested your article and it's don't worked... Could you see it again?
We have another sites and systems in the same server, we are in change's process aiming php7.
I will talk with server's owner for your access.
Thanks!
6 years 3 weeks ago #5 by valdenilson brito de araújo
