Whatsapp multi agent
Is possible to perform temporary disable agent in front end?
5 years 11 months ago #1 by Coopera srls
Hi coopera, can you elaborate the question? What do you mean by perform temporary disable agent?
5 years 11 months ago #2 by TemplatePlazza
Ok, I have three agents connected to the component.
Now, one moves in for a meeting with the customer. It should go offline!
What is the way to temporarily put an agent offline?
Is it always necessary to intervene from the CMS backend?
Thanks. Coopera
5 years 11 months ago #3 by Coopera srls
Hi, If your website allows frontend editing then user with access will be able to edit agent availability (see video below). But I think it's safer to disable it from backend
5 years 11 months ago #4 by TemplatePlazza
