Notice: Undefined variable: sliderControls
I get this message when in the backend I turn on navigation: No together with the adaptor slider.
Can you please help me out on this one?
The complete error message is:
Notice: Undefined variable: sliderControls in /var/www/vhosts/xxxxxxxxxxxx/httpdocs/dev/nauta2/modules/mod_responsivebannerslider/mod_responsivebannerslider.php on line 58 Notice: Undefined variable: sliderControls in /var/www/vhosts/xxxxxxxxx/httpdocs/dev/nauta2/modules/mod_responsivebannerslider/mod_responsivebannerslider.php on line 64
13 years 9 months ago #1 by Niels Bons
So sorry but I still don;t understand when/why this error happen
is there any similar error shown up in the frontend?
13 years 9 months ago #2 by erwinschro
This error message is shown in the frontend. But it only shows with the navigation switched off and the adaptor slider turned on
13 years 9 months ago #3 by Niels Bons
Ok I understand now...yes there's a little typo bug there.
Can you edit on these both lines
mod_responsivebannerslider.php on line 58 and line 64 from
$sliderControls==1
$sliderControls!=1
to
$sliderControl==1
and
$sliderControl != 1
save the file, see the result if the error gone. let us know then.
13 years 9 months ago #4 by erwinschro
Thanks, that solved the problem!
13 years 9 months ago #5 by Niels Bons
Ok thanks for your confirmation. We will update the module package ASAP.
13 years 9 months ago #6 by erwinschro
