Floating buttons conflict TZ Portfolio Plus component
Looks like Floating buttons module conflicts with TZ Portfolio Plus component - after publishing it I see no Floating buttons module, and the modules of TZ Portfolio Plus are not shown too.
In TZ Portfolio Plus component I see setting "Enable/disable JQuery" - tried it, doesn't have any good effect.
Also tried JQueryEasy plugin - it doesn't helps too.
Template - JD Paris.
Any suggestions?
5 years 11 months ago #1 by 6961296
Hi can you share your website url?
5 years 11 months ago #2 by TemplatePlazza
