Override mini frontpage template?
Is it possible to override mini frontpage templates? Trying to make some edits to match my site template and I didn't saw any info about that.
Thank you for any help. I don't know for now another way than modifiing the corefiles. Wich is not ideal in case of an update.
5 years 10 months ago #1 by ckubs
Hi, minifrontpage is fully support template override. Please have a look on this video to do that
5 years 10 months ago #2 by TemplatePlazza
Thank you for the response.
One of the reasons that made me wanting to override default templates is this piece of code from carousel.php that duplicates the default joomla 3.9 module title. It's quite annoing.
<div class="mfp_block_title"><h4><?php echo $module->title; ?></h4></div>
5 years 10 months ago #3 by ckubs
Hi you don't need to override the template for that purpose. You can use CSS adjustment tab from the module backend and hide that part by css
.mfp_block_title {display:none!important}
5 years 10 months ago #4 by TemplatePlazza
Should work that way. Unfortunatelly everything I override in my template CSS doesn't work without !important added as the mfp selector style gets picked over it.
5 years 10 months ago #5 by ckubs
