Order by title
Hi!
I'd like to have artikles ordered by title ascending.
I have modified MiniFrontpageHelper.php in a unprofessionell way and will loose it with next update, I know.
Any change to get it as a feature ... perhaps in prof. version? Or for a little donation in the free version?
Thanks,
Stefan
5 years 10 months ago #1 by Stefan Wulff
Hi Stefan, Can you tell me why you would need to order the articles by title ASC? Any example use?
5 years 10 months ago #2 by TemplatePlazza
Hi!
Of course:
I use Minifrontpage to show als List of articles (about 15 to 25), filtered by category and keyword.
Members use this list to select articles by name.
The articles contain music sheets and music examples and the module is used to give members of our choir quick access to selected pieces of music. It's difficult to find the right one, if it's not sorted by title.
Stefan
5 years 10 months ago #3 by Stefan Wulff
Hi Stefan,
Ok I will include this option for Minifrontpage pro in the next update
5 years 9 months ago #4 by TemplatePlazza
Ok, thank you!!:)
5 years 9 months ago #5 by Stefan Wulff
Hi, Just want to let you know that Minifrontpage 1.4.0 is already released and available to download from : www.templateplazza.com/items/mini-frontpage-pro
Changelog:
+ Added new Infinity theme, with Ajax and Infinity Scroll feature (available for Joomla 3.x and K2 version only. Joomla 4.x version is not yet supported due to some unresolved issues in Joomla 4.x Beta)
+ Added Show Tags
+ Added Title and Popularity (by Hits) ordering
+ Added Ordering direction option
+ Added item as background option to default theme
- Fixed image not found when trying to generate thumbnail, when wrong image url inserted
- Fixed same background image issue when multiple Collage themes with the same layout are published
- Updated some deprecated jQuery code
- Fixed some bugs on default template
- Fixed carousel themes (also Carousel Big and XT) issue on tablet (iPad)
5 years 8 months ago #6 by TemplatePlazza
