Hi Alex, yes you have to start allover. But I think it won't be that difficult, because the settings in minifp are also in minifppro, although some have changed and also there are some new setting items.
We separate the versions to make it easier for us to maintain the modules ( there are 5 versions to maintain actually, minifp (j3,j4), minifp pro(j3,j4,k2)).
5 years 9 months ago #2
