Mini frontpage title size
Hello.
I am using mini frontpage module and i wanted to ask if there is a way to change title's size, color, make them bold etc.
Thank you in advance!
13 years 9 months ago #1 by panos
Hi ,
Please try to add this css anywhere on your template css files :
.mfp-introtitle a {
font-size:40px!important;
color:#cccc00;
font-weight:700;}
13 years 9 months ago #2 by TemplatePlazza
Thank you very much for your prompt reply!
It works fine with your code! :)
13 years 9 months ago #3 by panos
Can you also tell me if I can link the introtext to the article? The thub photo and the title are links ok, but how about the introtext.
13 years 9 months ago #4 by panos
I won't suggest it but it's up to you to link your introtext
As an example you choose the following
Layout = Default
Other Article Placement = Bottom
then you need to edit the following file
/mod_minifrontpage/themes/default/tmpl/bottom.php
find this line
echo $item->introtext;
add link for it so that line will look like
?><a href="<?php echo $item->link; ?>"><?php echo $item->introtext; ?></a><?php
that's it. It will be the same for other layout and other article placement option, just find the correct file to edit.
13 years 9 months ago #5 by erwinschro
