Responsive Banner Slider PHP exceptions.
Our logs are getting hammered with the following PHP exceptions, which appear to involve the responsive banner slider:
A PHP Exception occurred on your site. Here you can find the stack trace:
Exception Type: JException
File: /home/mydomain/public_html/libraries/legacy/error/error.php
Line: 200
Message: Duplicate entry '2021-02-17 22:58:20-1-44' for key 'PRIMARY'
#0 /home/mydomain/public_html/libraries/legacy/error/error.php(277): JError::raise(1, 500, 'Duplicate entry...', NULL, true)
#1 /home/mydomain/public_html/components/com_banners/models/banners.php(333): JError::raiseError(500, 'Duplicate entry...')
#2 /home/mydomain/public_html/modules/mod_responsivebannerslider/helper.php(70): BannersModelBanners->impress()
#3 /home/mydomain/public_html/modules/mod_responsivebannerslider/mod_responsivebannerslider.php(389): modResponsiveBannerSliderHelper::getList(Object(Joomla\Registry\Registry))
#4 /home/mydomain/public_html/libraries/src/Helper/ModuleHelper.php(200): include('/home/mydomain/...')
#5 /home/mydomain/public_html/libraries/src/Document/Renderer/Html/ModuleRenderer.php(98): Joomla\CMS\Helper\ModuleHelper::renderModule(Object(stdClass), Array)
#6 /home/mydomain/public_html/libraries/src/Document/Renderer/Html/ModulesRenderer.php(47): Joomla\CMS\Document\Renderer\Html\ModuleRenderer->render(Object(stdClass), Array, NULL)
#7 /home/mydomain/public_html/libraries/src/Document/HtmlDocument.php(501): Joomla\CMS\Document\Renderer\Html\ModulesRenderer->render('mod_sponsors01', Array, NULL)
#8 /home/mydomain/public_html/libraries/src/Document/HtmlDocument.php(793): Joomla\CMS\Document\HtmlDocument->getBuffer('modules', 'mod_sponsors01', Array)
#9 /home/mydomain/public_html/libraries/src/Document/HtmlDocument.php(567): Joomla\CMS\Document\HtmlDocument->_renderTemplate()
#10 /home/mydomain/public_html/libraries/src/Application/CMSApplication.php(1044): Joomla\CMS\Document\HtmlDocument->render(false, Array)
#11 /home/mydomain/public_html/libraries/src/Application/SiteApplication.php(778): Joomla\CMS\Application\CMSApplication->render()
#12 /home/mydomain/public_html/libraries/src/Application/CMSApplication.php(202): Joomla\CMS\Application\SiteApplication->render()
#13 /home/mydomain/public_html/index.php(49): Joomla\CMS\Application\CMSApplication->execute()
#14 {main}[/code]
Any advice to solve this?
5 years 8 months ago #1 by CCANSW
- Can you tell me what joomla version do you use?
- Can try to publish only one banner and see whether the same issue happened?
- Can you try to publish multiple standard joomla banner module and check whether the same issue happened?
5 years 8 months ago #2 by TemplatePlazza
Thanks for the response
We're always on the current 3.9 stable. At this moment 3.9.24. PHP version 7.4
I shall reduce the banners to 1 and test. Will report back.
5 years 8 months ago #3 by CCANSW
With just one banner image slide published and one responsive banner module published the exceptions disappear.
Once I activated more banner slides and modules the frequency of the exceptions increased.
The frequency of the exceptions seems to correlate with the number of active modules.
5 years 8 months ago #4 by CCANSW
Can you try this one too?
5 years 8 months ago #5 by TemplatePlazza
Sorry, missed that, but will do...
5 years 8 months ago #6 by CCANSW
