Related Items Extended error After installation
  • Posted by DIMITRIS KAMARETSOS (15) Offline
1.After the installation I get the specific error
0
NO VALID IMAGE WAS LOADED.
When I turn off the module everything works fine
adapokrites.gr/adapokrites/diethneis-eid...as-synithisoun-geysi
adapokrites.gr/adapokrites/diethneis-eid...o-metro-tou-manxatan
2.I would also like to ask you if the extension it is possible not to create images.
Specifically the extension to use the already existing images of the articles.
This is the case with the other extension
5 years 6 months ago #1 by DIMITRIS KAMARETSOS
Hmm really strange, Let me check on your website. Will back to you soon.
5 years 6 months ago #2 by TemplatePlazza
Anyway, how did you add any image in an article? I found the module works properly in this article adapokrites.gr/adapokrites/paraksena-vid...eis-aeroskafon-video
5 years 6 months ago #3 by TemplatePlazza
I do not know exactly what is happening! It works on most articles. But it turns out the same problem that I sent you in many articles.
When I turn off the tool everything works normally.
5 years 6 months ago #4 by DIMITRIS KAMARETSOS
Ok, let me check it deeply on your website
5 years 6 months ago #5 by TemplatePlazza
All articles work with a 700x400 image.
The image is normally integrated by joomla content
Observation!
All articles that play on the website are after the first 300.
The first 300 are integrated with feeds
I will turn them off to see if this is to blame
5 years 6 months ago #6 by DIMITRIS KAMARETSOS
