minifrontpage
Thank you for such a good and useful module.
I am using minifrontpage in a couple of places in my website. When you open developer tools in chrome it shows that;
DevTools failed to load SourceMap: Could not load content for www.xxx.xxx/modules/mod_minifrontpage/tm...s/tiny-slider.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
Why this warning is displayed and is there a way to fix it.
Regards,
Aydin
5 years 7 months ago #1 by aydin
Hi its just a warning from Chrome Dev tool. It will be fixed in the next update. In the mean time you can go to inspect -> settings gear -> Uncheck 'enable javascript source maps' and 'enable css source map'.
5 years 7 months ago #2 by TemplatePlazza
OK, thank you for your answer.
5 years 7 months ago #3 by aydin
