Mini Frontpage
  • Posted by Christos Farakos (1) Offline
Hello, I have two question before I want to buy the Pro version.
1. Is it possible to exclude as single content item within a category? I didn't find any options for this.
2. I have set up a both a full article image and an intro image for an article, but the MiniFrontpage extension always is using another image. What ist the problem?
Here is a link to the extension:
www.griechenland-entdecker.de/insel-kreta
The second article "INSEL KRETA | REGIONALBEZIRK CHANIA" is an example where the image is wrong.
3. When I use the module and click then on any article, then it opens not with the URL which is setup for an article, but creates a new URL by using the alias. This creates duplicate content. How can I change this, so it takes the already created URL (which was created when linked the article to menu). I made it for now the a redirect, but this should work without. In backend in SH404 extension, I see that it creates always a new duplicate link.
Thanks an best regards,
Chris
5 years 7 months ago #1 by Christos Farakos
Considering that this module will show dynamic contents, meaning that it will continue to display the latest items, the option to exclude items in the category is not quite relevant. If you really need it there is a workaround for it. You can mark the article as Featured, and set the Featured article to not showedhttps://www.dropbox.com/s%2Frd3ogurdcs8awz7%2FMonosnap%25202021-03-19%252007-15-51.png?raw=1
It'w working good from here. Are you already managed to solve the problem?
https://www.dropbox.com/s%2Fz9vnker8ie2fu1a%2FKreta%2520-%2520Was%2520macht%2520die%2520Insel%2520so%2520besonders%25202021-03-19%252007-17-48.png?raw=1
The module uses the standard joomla route so I think it's just a known joomla's itemid issue. You can solve it by creating a hidden menu for your article category
5 years 7 months ago #2 by TemplatePlazza
