documentation for floating buttons?
where can I find documentation for floating buttons?
thank you
5 years 7 months ago #1 by John
Hi, Are you having trouble using the module? Just let me know. I think it's very easy to use the module. You can also hover your mouse over the label and a description for the setting will appear.
https://www.dropbox.com/s%2Fez3leq8g68k7tre%2FMonosnap%25202021-03-30%252008-28-44.png?raw=1
5 years 7 months ago #2 by TemplatePlazza
