Related item Extended ans SH404SEF
- Posted by Jerome Boccon-Gibod (9) Offline
Sometimes (often) I have a problem with Related item Ext and SH404SEF, the links are not modified by SH404SEF.
I guess it must a execution order problem but I don't know how to fix that ?
On every article page I have the module and sometimes the links stays with the default Joomla structure.
Ex : www.360images.fr/visites-virtuelles/auve...chaine-des-puys.html
A clue ?
5 years 7 months ago #1
A clue ?
Hmm Related Items Extnded module generates the link using standard joomla JRoute API. It should be no problem actually.
Anyway, can you try to create a Category List menu for the articles and then see whether the links is changed?
https://www.dropbox.com/s%2Fhv6e26himy4vgqo%2FMenus%2520New%2520Item%2520-%2520J39%2520-%2520Administration%25202021-03-30%252020-05-59.png?raw=1
5 years 7 months ago #2
Category list works alright.
Just realized that I had Joomla core cache enabled while I'm using JotCache plugin, maybe this where the bug comes from ?
5 years 7 months ago #3
Ah ok glad it worksCategory list works alright.
I don't think so, but I'm not really sure about that.Just realized that I had Joomla core cache enabled while I'm using JotCache plugin, maybe this where the bug comes from ?
Well, problem is not solved, on some page the related articles links urls are not transformed by SH404SEF.
If I clear all cache manually it works, but when cache is updated auto (every 2 days) then problem comes back.
For example : www.360images.fr/visites-virtuelles/new-...yn-et-manhattan.html
The 3 thumbnails links at the bottom (related item module) are not transformed correctly : category is transformed but not article html page.
www.360images.fr/visites-virtuelles/new-...r-230-fifth&catid=62
should be
www.360images.fr/visites-virtuelles/new-...p-bar-230-fifth.html
A clue ?
5 years 7 months ago #5
should be
A clue ?
Are you sure you have created hidden menus for all of your article categories?
5 years 7 months ago #6
