Whatsapp MultiAgent sets off Malwarebytes
Whatsapp Multi Agent causes Malwarebytes to create a Suspicious Site warning. Is there anyway to avoid this? www.petermatra.design
Pete
5 years 7 months ago #1 by Matra
Really? Can you tell me how can I replicate it?
When you disable the module, does the warning persist? Can you check demo.templateplazza.com/joomla/index.php/whatsapp-multi-agent . Does malwarebyte also create a Suspicious Site warning on the demo site?
5 years 7 months ago #2 by TemplatePlazza
Well I chose to ignore the warning so it has gone away for good. Your site/link didn't come up as malicious so I don't know why mine did. I'm going to run a virus scan on my server to be sure its not something else.
5 years 7 months ago #3 by Matra
Ah ok then.
It’s a bit weird anyway, because there is no uncommon part/codebase in the module. It’s just using standard js and css. Also there’s no report before this.
5 years 7 months ago #4 by TemplatePlazza
