Whatsapp multi agent problem
- Posted by Pietro (4) Offline
Hi! I have a problem with my website (www.hotelboschetto.com)
When I open website I have this error and website doesn't work.
Hai bisogno di aiuto?Chatta con noi!
Fatal error: Call to a member function modify() on boolean in /home/customer/www/hotelboschetto.com/public_html/modules/mod_whatsapp_agent/helper.php on line 27
How can I solve it? It seems a Whatsapp multi agent problem. Thank you
5 years 6 months ago #1
by Pietro
Hi Pedro, Can you share temporary access to your website so I can have a look on it directly? If you can, you can share it in the Your Site Details tab below. Only you and support staffs who are able to see it.
5 years 6 months ago #2
Hi I have added some changes to the module. Can you please try again?
5 years 6 months ago #4
I think it's something related to php version or something server related because I'm unable to replicate the problem at my end. I commented lines of code on the helper file on the dst support part and then it's working properly.
5 years 6 months ago #6
