Mini Front Page PRO K2 · thumbnails dimensions
- Posted by Javier Ballester (11) Offline
the destination page has an image (introtext) 175 x 120
We configure thumbnail 175 x 120 Mini Front Page for K2 on the main page but it generates thumbnails of 525 x 360 px with poor quality image
Cache clean but nothing changes
5 years 6 months ago #1
by Javier Ballester
Hi, Minifrontpage use standard joomla's JImage APi to create thumbnail. It will generate a blurry image when the output image is bigger than the original one. You choose 175 x 120 as the defined size but because you set the Retina Support to 3x then the module will try to generate 3x of 175x120 = 525x360.
So, try to set Retina Support to No.
5 years 6 months ago #2
