Float Buttons - sub icon missing
I just installed floating buttons on my site. When I click the button the sub menu appears, but the icon I selected in the module is missing.
I thought maybe as I don't have font awesome, so use a free icon font called Lineicons? If so, how do I include this font into the module?
Thanks.
5 years 6 months ago #1 by Nigel Jackson
Hi, It doesn't use fontawesome, but Material Icons. It's called on the fly directly from google font repo. Actually you can upload your own icon image. Have you tried that?
https://www.dropbox.com/s%2Fiwh302m0zp6yywg%2Fmodules%2520floating%2520buttons%2520-%2520j39%2520-%2520administration%25202021-04-22%252018-27-10.png?raw=1
5 years 6 months ago #2 by TemplatePlazza
Yeah I saw Material Icons in the css file after I posted!
Is there anything I need to do to enable the site to see the Google font repo? I have an icon selected so it should be visible in the front end.
I haven't tried my own icon yet but will do that if I can't get the Material Icons to work.
5 years 6 months ago #3 by Nigel Jackson
Can you tell me your website url?
5 years 6 months ago #4 by TemplatePlazza
It's a secure intranet site.
I can give you support access on Monday but need a way that is private/secure to give you the credentials. I'll need your IP address for the firewall.
5 years 6 months ago #5 by Nigel Jackson
If you're in a secure internet, you can download the Material Icons directly and call the local version from the css
5 years 6 months ago #6 by TemplatePlazza
