Template compatibility
- Posted by COB (8) Offline
Just bought Whats App Multi agent
Installed and activated it
Set in right position of my template
NOTHING ! Module dont show
I'm using Template Toaster with right, left, menu etc..positions
I tried several but cant show your module
Could you help me ?
Philippe ( From France)
5 years 6 months ago #1
by COB
Could you help me ?
Hi, I tried to login with the credentials you provided but it returned error message : Login denied! Your account has either been blocked or you have not activated it yet.
5 years 6 months ago #2
Ooops ! Sorry,
The account was not activated
It is now.
Note : Your module is called : Parlons-en !
Thanks for any help
Philippe
5 years 6 months ago #3
by COB
It is now.
Thanks for any help
Philippe
Hi Phillippe,
I tried to publish it in the position RightFooterArea and set the access level to public + seems it's working good. Can you check it please?
5 years 6 months ago #4
No way !
Even on Chrome or Firefox
May be a firewall or antivirus in action ?
However, i want this module only for registered users not the public.
I used it previously on an Artisteer template ( obsolete now) and it worked fine.
Could you explain?
5 years 6 months ago #5
by COB
Could you explain?
Hello again
It works now!
It's magic
Thanks for your help
May I know what you did ?
5 years 6 months ago #6
by COB
It works now!
It's magic
