Display files via mini front page PRO
Hello team,
I use the module Mini frontpage Pro and provide PDF files that come from the article to open.
At the moment it is so that if you click on the title or the picture you land on the detail page of the article, but this is too cumbersome for my application because I don't want to use a category page.
The category should ONLY run through this module.
I would like the PDF icon to be visible to the visitor and to be able to open it immediately.
It would also be nice if you could remove the link from the title and the image to the data page so that you don't end up there in the first place.
You are welcome to take a look at the page, here is the address:
hesse.demo-hmstepweb.de/
Or is there a combination that you can implement using the flying modules, in which case I would still purchase this?
Thanks in advance
Best regards from Hamburg
5 years 6 months ago #1 by Henryk Mierzwa
Hi, I'm not really sure what you're trying to achieve. Can you explain it in more detail? Can you publish the module somewhere on your website and then tell me what you want to have?
5 years 6 months ago #2 by TemplatePlazza
Sorry, was not entirely understandable,
But it's very simple ...
The standard is that minifronpage does not show any links from content.
I just want the icon (PDF) to be opened as a link on the start page in the module.
You can see the module on my home page at the top right next to the slider and there I would like the PDF link to be included so that the visitor is not first redirected to the category level.
Thanks!!
5 years 6 months ago #3 by Henryk Mierzwa
Am I missing something? I can't see any minifrontpage pro module published on the home page
https://www.dropbox.com/s%2Ffov66f7tfjj0n2x%2Fhome%25202021-04-30%252019-51-06.png?raw=1
5 years 6 months ago #4 by TemplatePlazza
Oh ... on the German side
5 years 6 months ago #5 by Henryk Mierzwa
Hi, you do that by creating a template override. If you don't know how to create template override you can follow this video :
Then open the template file depends on what theme you use then find this code :
echo JHtmlString::truncate(strip_tags($item->introtext), $introtext_truncate);  ?>
change that with
echo $item->introtext; ?>
5 years 6 months ago #6 by TemplatePlazza
