floating buttons
Hello, I have installed the floating buttons module. Everything works fine on the desktop. When using via smartphone, a frame appears around the png image. Can you disable the frame via CSS. Thank you for your support.
Best regards
5 years 5 months ago #1 by Armin Neuberger
Can you tell me your website url so I can check it?
5 years 5 months ago #2 by TemplatePlazza
Hello, thank you for the quick reply. Please note, the error appears on the smartphone. Thanks for your effort
5 years 5 months ago #3 by Armin Neuberger
Yes, please tell me your website url so I can check it
5 years 5 months ago #4 by TemplatePlazza
Hello would not like to put the link online. Is there another way to send the link to you?
5 years 5 months ago #5 by Armin Neuberger
Hi sorry for delay in responding. You can post it in the Your Site details tab below. Only you and support team who are able to see it.
5 years 5 months ago #6 by TemplatePlazza
