Minifrontpage for K2 have stopped showing images.
- Posted by Javier Ballester (11) Offline
HI,
suddenly the slider minifrontpage for k2 carousel banner module have stopped showing images.
All are inside the module with a display: none, and none active
Thank you
Javier
5 years 5 months ago #1
by Javier Ballester
Thank you
Javier
Hi I visited your website, and looks like everything goes fine. Can you point me to the page where the issue exist?
5 years 5 months ago #2
Hi, yes,
on the main page, contains two modules, Sliders and Newsflash. (Carousel and Minifrontpage)
At the moment these modules are only visible via code
Thank you
Javier
5 years 5 months ago #3
by Javier Ballester
Thank you
Javier
- Can you try to publish those module in other module position to see whether this is related to a specific module position?
- can you try to unpublish modules published on the frontpage, one by one to check whether there is a module confliction issue?
- Your website have some console errors, can you check what cause those errors?
https://www.dropbox.com/s%2Fq4vp737tdwpts72%2Fpro%2520instalaciones%2520%2520portal%2520web%2520con%2520toda%2520la%2520actualidad%2520profesional%2520y%2520tcnica%2520en%2520un%2520slo%2520click%25202021-05-25%252022-52-07.png?raw=1
- Can you publish those modules in protostar template to see whether this is a template related issue or something else.
5 years 5 months ago #4
Hi, solved.
unpublishing the Rockbox search engine, the conflict disappears.
Thank you
5 years 5 months ago #5
by Javier Ballester
Thank you
