Mini Frontpage not showing article pictuer
- Posted by MaagoFleesa (4) Offline
I'm very new to the Mini Frontpage module. Before buying it I will test it on a test site.
What I do not understand is how and when intro pictures are loaded or not. Currently only the default picture is loaded, nothing from the article picture.
How can I set:
- module default picture if nothing in article
- article picture if there is any picture in article settings
The used template is Helix3
5 years 3 months ago #1
by MaagoFleesa
How can I set:
Hi, When generating thumbnail, Minifrontpage will first try to find intro image from the article. If no intro image found then it will try to find in full text image. If still no image found then the module will try to find first image from the article body. If still no image found, then the module will use default image.
Hope this helps
5 years 3 months ago #2
Hope this helps
Ok, thanks for your answer. Would be good if that works .. but it does not.
I have in one article article picture, intro picture, featured picture inserted, but no one is displayed in Mini Frontpage.
5 years 3 months ago #3
by MaagoFleesa
Can you try to delete all images located under this folder : test.montafreunde.de/images/thumbnails/mod_minifrontpage/ and then refresh your browser?
5 years 3 months ago #6
