WhatsApp Multi Agent - white error screen when enabled..
- Posted by Steven Northam (3) Offline
I have been using this for a while with no problems, I recently updated and now I get the following error:
Error: Call to a member function modify() on boolean: Call to a member function modify() on boolean
this crashes the whole site and it just a white screen with the above error message when I enable the whatsapp multiagent module.
5 years 4 months ago #1
by Steven Northam
Hi, Can you share temporary access to your website so I can have a look on it directly? If you can, you can share it in the Your Site Details tab below. Only you and support staffs who are able to see it.
5 years 4 months ago #2
Ill need to get authorisation from our sys admin to give access - ill come back on that.
I saw on another post it may be something to do with DST? are the lines within the helper.php file which can be commented out to remove the issue?
5 years 4 months ago #3
by Steven Northam
Yes, it's something related to DST but. Strangely it happened only on some servers. Temporarily you can comment these lines below in the helper.php at lines 27 - 28 so it becomes :
5 years 4 months ago #4
// $start = $start->modify('+ 1 hour');
// $end = $end->modify('+ 1 hour');
