Introtext Links deactivated
  • Posted by template monster (4) Offline
I have the problem that links are deactivated in the intro text. This means that I have linked text in the post. As soon as the post is output via Minifrontpage (Introtext), the link is gone.
Unfortunately I can't show an example, the page is currently set up locally.
I would be grateful for a tip. I suspect that some PHP expression deactivates it. Also, the class of the link is not output. I don't know PHP very well. Can someone help me, please?
5 years 3 months ago #1 by template monster
Hi, you can create a template override (please follow this video if you don't know how to do it
) and then at line 111 modify this code :
echo JHtmlString::truncate(strip_tags($item->introtext), $introtext_truncate);  ?>
into
echo $item->introtext;  ?>
5 years 3 months ago #2 by TemplatePlazza
PERFECT!!!
That's exact what i was looking for. I already tried at this point, but was wrong with the syntax. Now it works!
THANK YOU VERY MUCH!!
5 years 3 months ago #3 by template monster
