Jbounce displays strangely
Hi there,
I keep trying to use Jbounce, and it keeps looking odd when I do!
I have it installed on DogParents.ca
When it pops up, the live menu item always displays over the module, and forms etc too. I also can't close it with the X - only by refreshing. Any idea how to fix that?
Thanks!
5 years 2 months ago #1 by Tamara Aspeling
it's usually a css confliction matter with your template's css. Can you share your website url?
5 years 2 months ago #2 by TemplatePlazza
Thanks. As mentioned above, it's DogParents.ca
5 years 2 months ago #3 by Tamara Aspeling
Try to add this css code to your template :
#jbounce-jmodal {
  z-index:9999!important;
5 years 2 months ago #4 by TemplatePlazza
