Floating expands downwards
Is it possible that your Floating Buttons module can be modified so that it expands downwards?
It would be very useful to use it in the header as a secondary menu. Thanks
5 years 2 months ago #1 by David
It's technically possible but you will need js and css knowledge to modify the codebase.
5 years 2 months ago #2 by TemplatePlazza
