newsy layout
Newsy Layout is closing the extra div tag, breaking my layout.
Note: I am Brazilian, using Google Translator.
5 years 2 months ago #1 by Bernardo
Hi, Are you sure about that? Because no one has reported it before. Can you tell me your website url?
5 years 2 months ago #2 by TemplatePlazza
Good night, I'm sure, I ended up doing more tests and I believe I have located the error.
When the "Number of Column" field is equal to 1 and the "Number of Hero Item" field is 0, it looks to me like it's closing the div tag of the Hero field that doesn't exist.
The "Outras tabelas" Module is in the right position inside the asid tag, the source code (Ctrl + U) will be able to see better, unlike the Gift Inspector (F12).
5 years 2 months ago #3 by Bernardo
Ah I see. But if you want to set the Number of Hero item is 0 then it is better to use default theme for that purpose as it will produce the same output.
5 years 2 months ago #4 by TemplatePlazza
Understand. It's just that Default doesn't have a line separating the links like Newsy.
Thanks.
5 years 2 months ago #5 by Bernardo
To have that line you just need to add this code to the CSS adjustment tab :
.mfp_default_item > div {border-bottom:1px solid #ddd;padding-bottom:1em;}
5 years 2 months ago #6 by TemplatePlazza
