Invoice and Error message
Hello, I just bought your module : Whatsapp multi-agent.
Can you please send me an invoice with this information :
Smart - Monkeys
avenue de marlagne 24
5000 Namur
Belgium
BE0769867026
Also After installation and setting I got the error : 0 - Call to a member function modify() on bool
If I remove the agent the problem does not appear... but I need to add some agents.
5 years 2 months ago #1 by Smart Monkeys
Hi, regarding the invoice can you please contact us using the contact form at :
www.templateplazza.com/contact-us
Regarding the error
I have fixed it, can you check it?
5 years 2 months ago #2 by TemplatePlazza
Thank you it works.
I'll send a request to your contact form for the invoice.
Best regards.
5 years 2 months ago #3 by Smart Monkeys
Ok Glad we coud help ;)
5 years 2 months ago #4 by TemplatePlazza
