Minifrontpage doesn't generate Thumbnails
- Posted by luz quintero (24) Offline
Hi. I have a Minifrontpage pro and has always worked well. But i update to joomla 4 and i update the extension to version joomla 4.X
and the new modules only show the thumbnail by default.
I tried to regenerate all the miniatures and all the modules, old and new have stopped generating miniatures and puts the miniature by default. Can you help me?
Thanks for your help.
4 years 11 months ago #1
by luz quintero
Hi, can you tell me what version do you have on your website
4 years 11 months ago #2
Can you try to re-download the extension and install the minifrontpage for 1.5.1 (for joomla 4)?
4 years 11 months ago #4
I have installed the new version, the result is the same. I have deleted the thumbnails, I have cleared the cache and the thumbnail is set by default. I don't know what I'm doing wrong, I have already checked the permissions of the folders and everything is ok. I don't get any error. I send you the access data to the web.
4 years 11 months ago #5
by luz quintero
Hi biviana, I tried to open your website and it returned 500 error message. Are you currently working on it or the website indeed having an issue?
https://www.dropbox.com/s%2F1v0nmkoknsp7kss%2Fmonosnap%25202021-09-28%252018-45-06.png?raw=1
4 years 11 months ago #6
