my Custom Default Thumbnail.not shows up.
When setting the Custom Default Thumbnail to my own thumbnail. Only the first Item of a category got my Custom Default Thumbnail. Is this a bug? What to do? I want to purchase the PRO version but wonder if my issue goes well.
Joomla 3.10.2 - PHP7.4.23
Regards, Milian
5 years 1 month ago #1 by Max
Hi milian,
Have you tried to delete all images under this folder :
/images/thumbnails/mod_minifrontpage so the module can regenerate the thumbnail?
5 years 1 month ago #2 by TemplatePlazza
Aha. thanks. It works that way.
BTW:
Is there a field where I can add "read on >>" for clicking to the article. Or is this feature only availlable in the PRO version?
Regards, Milian
5 years 1 month ago #3 by Max
I will add the 'read on' button in the upcoming version. Temporarily you can add the read on button by using template override.
5 years 1 month ago #4 by TemplatePlazza
Thanks. That should be great.
users are common with "read more".
Regards, Milian
5 years 1 month ago #5 by Max
Hi, I just installed mod_minifrontpagepro_j3.zip
After setting the parameters to mu needs, I got an error: 0 - The image file does not exist.
But all the images are present in images/thumbnails/mod_minifrontpage/fab919f26747d1e7b5c284eb55f73abf.jpg a.o.
Why is it not working out of the box?
I installed mod_minifrontpagepro_j4.zip on Joomla 4.0.3 and everything worst fine.
What to do?
Regards, Milian
5 years 1 month ago #6 by Max
